GoinTopless240 »
https://forums.nicoclub.com/gointopless240-u37872.html
Mon Nov 23, 2009 2:50 pm
Honestly.. ear plugs were too funny and for this group - on par (goes with the family atmosphere). A couple of things you may not realize are adding to the road noise. At the current age of our vehicles, almost anything remotely rubber and a bushing or insulator, is probably shot. At this age they have turned into hockey pucks (control arm bushings, sub-frame bushings, transmission mount, motor mounts, tension rod bushings). Another thing to consider are the tires. High performance tires usually add road noise because of the way they are made (lower profile tires magnify this as well). I've changed out a few of the pieces and have noticed a slight reduction in harshness, but I've SR'd mine and am running a flowmaster 20 mounted under the drivers seat. Hope this gives you other things to consider.
