highway cruising problem
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
Ok, so my car runs, but when cruising at highway speed its hard to keep a steady speed. Its like I have to be in boost all the time to maintain a speed of 75-80mph and its bugging me...
My timing is good, i set that last night.
It does have a misfire but I have yet to pinpoint whether its the plugs, coilpacks, or ignitor.
Any other ideas?
float_6969
O2 sensor? Minor vac leak? Do you have a vac/boost gauge? Does it seem to give you problems right around atmospheric pressure?
sjbsuperman1425
CA18DET
Yea it does, it stumbles coming into boost and around atmospheric. O2 sensor was replaced when I did the swap 3 years ago?
D_Stirls
Car: Nissan 180sx 1990 Ca18det
I had the exact problem when i first bought my 180 and it turned out to be a faulty O2, it was pulling fuel when it was already lean and then it wouldn't run right until i put in enough throttle percentage to revert to the open loop and run off the Maps.
float_6969
^This
Or maybe a FPR, but most likely a bad O2 sensor. Do you have a wideband? What do the AFR's look like when it breaks up?
sjbsuperman1425
CA18DET
Yea I have a wiseman but the shop that installed the bung in the exhaust didn't make the hole big enough so I don't have the sensor in and calibrated yet. That will happen Monday.
On another note, on my way to work today the car drove fine and I had no problems. Cruising vacuum around 5-6" at 80mph
float_6969
That's wierd. Now it sounds like an electrical problem. Grounds are all good?
sjbsuperman1425
CA18DET
Yup, grounds are all good.
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
i had this same issue right after i finished my swap. it was a bad O2 sensor
sjbsuperman1425
CA18DET
im really hesitant to condem the O2 sensor since I replaced it pre-swap and its only been 3 years..
I still haven't gotten my wideband in yet (Wednesday for sure). Any other ideas besides grounds and O2 sensor? I have a little trouble having it start on Cold-starts, but once it gets idling its good and will cold idle at around 1400rpms. But once its warm and in closed loop, it idles around 8-900rpms and has a misfire, and of course the intermittent troubles on the highway im having..
D_Stirls
I know you don't want to hear about the O2 sensor, but there is a way to test it. If you unplug the O2 sensor the ECU will run off maps all the time. If you have it unplugged and it still has the same issues then it isn't the O2 sensor.
sjbsuperman1425
CA18DET
I will disconnect my O2 sensor tonight and see how it drives on my way to work tomorrow. I also did get my Wideband hooked up and calibrated so I can finally see what my air/fuel ratios are. its pretty cool lol I get an a/f ratio of 14.0 on cold start.
sjbsuperman1425
CA18DET
Well I left the o2 plugged in and my afr's were around 14.1-15.6 and hit 17 at a couple times when in at about atmospheric..
sjbsuperman1425
CA18DET
Anu
Car: Nissan 200SX s13
An AFR of around 17, was that after releasing throttle? Then it is pretty normale because no fuel is being injected right after releasing.
When it is under load then be very carefull not to damage anything because that is very lean.
sjbsuperman1425
CA18DET
What about fuel filter?
sjbsuperman1425
CA18DET
ok i'm thinking the fuel filter is the culprit. Not only do I have the problems on the highway, but even with city driving, when coming into boost, i get a LEAN misfire/sputter. A/F Ratios of over 16 at this area. I'm leaning towards fuel because its lean. What do you guys think?
float_6969
So can you not get into boost at all? Does it lean out and then get rich, or does it break up and you can't get past it?
sjbsuperman1425
CA18DET
It just leans out around atmospheric. I can boost fine.
float_6969
If it was fuel volume related, it would break up at high loads, but be fine elsewhere. I could be a failing FPR, but that's not likely.
boost_boy
Did you plug the vacuum nipple under the throttle body? Most people don't do that and their cars have strange little problems that they can't figure out because they've over-looked the little things. Sounds like a stinking vacuum leak to me. And the CA18 have a few areas that it tends leak from besides the the intercooler piping ;) .
sjbsuperman1425
CA18DET
i blocked it off, but then again, idk how tight the thing is that I have on there. Replacing the fuel filter seems to help a little bit, but there is still a slight lean around atmospheric. I'll check out the TB nipple tomorrow.
btw, new thing happened today. the tach starts jumping around when i get into boost..damn car lol
cbh148
Car: 2000 Civic Si, 1993 240sx Hatch CA18
bump -- whatever ended up being the culprit?
sjbsuperman1425
CA18DET
well...its better now...i dont recall exaclty what I did, but I cleaned the grounds really good for the ignitor and all that area and the car runs fantastic. I still have to be almost to atmospheric to old 100-120km (about 80mph) though..which really bugs me. I think i have a couple more grounds to clean. I'm getting 19mph with my car too....i think I may change the O2 sensor like everyone was saying just to see if it helps at all
