Highly Reccomended!
Get240DiZzY
Car: Rallying. My 240. Not at the same time though.
I just got done take that fugly door carpet off, and I'm VERY pleased with the results. I would definitly recommed doing this. Takes about 45 min, a philips and flat head screwdriver, and some patience.
gunclap
hey that looks better. so you just take the carpet out and it looks like that, or you had to replace the carpet with something else?
Just another 240
yo that's neat...write up a "how to do it" thing.
89240sx
that looks great, i'm gonna do that!
did you have to put anything on it?? or is that the way it looks underneath?
Get240DiZzY
It's easy as pie to do. Materials needed- Philips head screwdriver and a flat head screwdriver.
All you have to do to prep the door is take off the passenger hand hold on the passenger side, the little wells on each door, they have a philips head screw in the bottom, covered by a pry- outable plastic thingy, and remove the plastic from around the door opener and lock. The well and lock cover come out with a little "persuasion," to get the lock molding out, make sure the door lock is in the unlocked position, and the door handle is pulled open. Then use the flat head screw driver and pry it out. For the well, take out the philips head screw in the bottom and pry it out with the flat head also.
Once the door is prepped, take the flat head screw driver and stick it in the edges where the carpet meets the plastic part of the door, and pull the edge of the carpet out of the crack. stick the screwdriver sideways into the crack and pull it outwards to quickly remove the rest of the edging.
Once all the edges are out, it's time to get that carpet off. Start from the outside of the door, because this is the easiest. Just yank at it, if a little but tears off, you can either come back for it later, or pull it up then and match it back up with the rest of the carpet, which is easier. Don't worry if some of the vynil underneath comes up with it, not tears, just comes unstuck. It should stick back down when you press it back against the door.
When you've got the carpet off, you should clean the door. I just took a swipe at it with some Armor All and it cleaned up nicely. Then, just re-attach the parts you took off, and viola, no more fugly door carpet!
If you have any questions about this, or my instructions are too vague (I'm sorry, this is the first "how to" I've written), just hit me up on AIM. My screenname is Doug The Mighty. You shouldn't need to much help though, it's not a very difficult project. Takes about 30-45 minutes, and for you worriers, there's almost no chance of the vynil underneath ripping.
Get240DiZzY
gunclap wrote:hey that looks better. so you just take the carpet out and it looks like that, or you had to replace the carpet with something else?
Nope, it's like that underneath.
I hope that helps. Like I said, if you have any questions, my AIM screenname is Doug The Mighty.
Smurf6x6
Car: 93 CA18 Coupe
Think you could do that with the glove box too?
Get240DiZzY
NONONONONONONONO!!!!!!!
Don't mess with the glove box!!!!!!
It's completely different stuff. drnovascotia put some vynil over the glove box, and it looks sweet, I think I might give it a whirl. I can post pics of that when I'm done. Don't even try to do the glove box, it's way different.
drnovascotia did all this first, I'm just the messenger. You can see pics of his stuff at http://home.kc.rr.com/jakes/240sx.htm
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
Wow, that makes the s13 doors look amazing. I'm so glad I dont have to worry about that stuff though, especially the glovebox carpet, heehehh
Smurf6x6
Car: 93 CA18 Coupe
drnovascotia car looks sweet.
p00t
wow... nice!!!@!!!!!!
something so simple yet..... ahhggg!! i bet if you colored that panel piece and had the whole interior follow the color scheme it would look complete badass.
'91 240sx
I've been looking into getting vinyl to replace the carpet on the doors, but now it looks like I wont have to, I think i'ma do this tomorrow when I wake up, I actually cant wait to do it
89240sx
Me too!! :D
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
nice work! looks awesome! i wanna see it in person!
-Dan
MeyDay240
Car: bball, track, cars, girls
that looks tight.....cant believe thats all you do, i might have to look into that.
rudee023
Car: '03 Infiniti Q45
Cool! I'm doin' tomorrow. Amazing nobody else has done this yet.
Get240DiZzY
p00t wrote:i bet if you colored that panel piece and had the whole interior follow the color scheme it would look complete badass.
Look at drnovascotia's pics... the color scheme is black, but still...;)
SingleCamSam
Just did it! Easy as pie. There were some holes where the vinyl came off with the carpet but it was an easy fix with liquid leather. :)
'91 240sx
I did it this morning and I love, I need to get some of that liquid leather stuff that Single said about because I got several little holes too
Big Perm
finished mine about 5 days or so ago. I first tried to cover in black vinyl but after about 15 minutes is said forget that!! I used a DAP patch stick to fill those little holes and then sanded with some 400 grit to give it an even texture. I then sanded with some ultra flat black Krylon. Painted the door handle and door pull a gloss black to match my dash. I am very pleased with the result. Very easy to do. Great improvement over the ****ty carpet.
Perm
Big Perm
what a dumbass. I didn't sand with Krylon. I sprayed. Sorry a too many cobwebs still left in the head from a blur of a weekend.
240SX
Car: Killin all imports
Is it the same if u have automatic windows?Thanks
