Highest Safe Boost On Stock Motor?
RoofusX
The car will have a FPR, and a 255 Walhbro, new cold plugs, and probably a intake. We are installing a manual boost controller.
What is considered a safe amount of boost on the stock bottom end? From past experience with turbo cars, I would personally think no more than 1 bar. What are your thoughts?
Nismo1182
Car: Z06
1 bar (14 psi) is good. Anything else, youd better run bigger injectors, bigger maf, some sort of ecu programming (afc works).
slw240sx
Car: 1990 Ca18det 240sx Hatch
i can only get 11 psi before boost cut
