that was only one tank calculation, more to follow after weekendmaxwell867 wrote:not bad, i thought it would be less. I'm definately considering installing 4.08 rear.
did you factor in the 10% difference in speedo?FarFetched wrote:I was getting 17-18 Mpg when I did 4.08 swap with almost 40-60 hwy-city driving. At least 2-3 WOT per day to clear carbon deposits from pistons/chambers If everything goes as planned, at the end of this year I might get 00-01 Y33 non-T
Actually, Wes meant odometer.elwesso wrote:did you factor in the 10% difference in speedo?
i have a 3.90 speed gear more like 5% thus my mpg really like 15.2mpg which is close to my former average of 15.36Q45tech wrote:A 4.083 with a standard speed gear has a speedometer off 15.4%......... of course the odometer is also off by the same amount.
