Sil240 wrote:If you want to hit 600 hp, your going to want more displacement.
Stroke it with a RB25 or 26 crank or switch to a 25/26
Google RB24, you'll find some more info.
I've heard of ones hitting 700hp never seen them, just heard.
It's either up the displacement as Sil240 said or rev it up higher as mentioned before... make sure you're head can rev... and if you're stuck on staying at 2L consider going with a drysump. The RB20 head is fairly restictive, so you should also consider doing what you can to make it breath better...
For 600hp (whp?) you will want to what you will have to rev to before you pick a intake/exh manifold and a turbo... these will all change base on where you want to make peak tq and your ultimate rev limit... also if you're reving it you'll need to run numbers with the internal parts you'll be using (including valvetrain) as weight becomes a very important factor with higher than avg rotating speeds
Hope this helps
