You are completely right, PSI is no indication of air density, just pressure.It all has to do with efficiency,wheel size,blade pitch and compressor housing size.The larger turbo doesn't have to work as hard(it's more efficient) to produce the same boost.lets say your outlet temp on a t25 at 14 psi was 150 deg, and on a t3/to4e 57 trim it was 120 deg,these numbers are just for arguments sake. you will make more power with the t3/t04e because the cooler the temp the more dense the charge air.We all know that cooler temps are more dense so that tells us that the cooler charge will be able to pack more air molecules in the same given area (motor) as the latter.As 240z twin turbo stated, this is a small piece of a big puzzle, but I hope it helps.240Z TwinTurbo wrote:You haven't been taught very much by any of these explanations. Do not equate PSI to flow as PSI seen is a function of many things. What creates the pressure you see? For a given compressor speed, any resistance to flow will create an increase in pressure. A good example is to place a pressure gauge on your air compressor line and start it blowing. If you place your finger over the nozzle the pressure in the line will increase, but you have actually decreased the flow coming out of the nozzle. Now to answer your question of how 2 different turbo's with the same running pressure and intake temps can make different power on the same motor. When you look at the compressor maps they are rated in lbs/hr which relates to the density of the charge. What does a compressor wheel do? It compresses the air making it more dense. Sorry, I like to ramble. So, for a bigger turbo it will pack more air molecules into a fixed volume as compared to a smaller turbo. Even though you have the same pressure you have more efficiently compressed the air molecules, making the charge more dense. The more air molecules you can pack into the motor the more power you will make. Just to give a real world example, if you are running a whimpy T25 @ 15psi you may make 300hp, but swap to 60-1 @ 15psi and you may make 350hp. No more boost, but more air molecules are put into the motor. Turbine efficiency and other factors do affect you ability to make more power, but I am just trying to convey how this stuff works in a simple way. I hope this helps.
