big jon's 240 »
https://forums.nicoclub.com/big-jon-s-240-u1784.html
Thu Dec 05, 2002 8:12 am
Higher revs do not neccessarily mean higher hp, yes HP=rpm x tq / 5252, but there really is more to factor in than that simple equation. If it were that simple every car around would have an 8000 rpm redline. The torque/hp curve on a KA24 starts to drop after about 6500 rpm. Changing the redline is not going to change this, it is inherent in the engine design. Now im sure it could be changed, but its probably not worth the time and $$$. And i understand that gear ratios also come into play, buy outside of 1st and 2nd gear its probably not enough to make a huge differece. (thats a guess, i have no idea what the gear ratios are in the 240)But go ahead and try, i wish you luck.
Oh, i almost forgot, if your power band was between 3500 and 8000, and mine was between 3500 and 7500, i will still win because i am the better driver!:D
