Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Tue Sep 03, 2002 11:49 am
Increasing the redline on the KA is simply retarded until you have it built (head, internals, etc.) for the higher rpms. You risk floating a valve which causes a free-for-all in the combustion chamber that results in FUBARed Pistons, Head, and sometimes the Rods can torque and grind the remaining piston against the block for added pleasure. High power cam profiles will open the door to higher rpm because there for one will be power up there. You will need new retainers, springs, cams, rods, and pistons for the higher RPMs and items such as a balanced or knife-edged crank and lightened flywheel will take some of the inertial load off the bearings in these before mentioned parts.
