trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Fri Jul 26, 2002 12:16 am
Cam would be a good thing to do while you are in there, but pistons and rings are a little different. It require a significant amount of extra work to do those, as well as alot more machine work. Yes, higher compression pistons will give you more horsepower but I would NOT recommend getting the high compression pistons if you ever plan to go turbo on that engine. If you are dead set on doing the pistons and rings, here is what I suggest. Tear the whole thing down, and build it forged. Pistons, rings, and rods, maybe even have some crank work done. Get the stock compression pistons, maybe even lower. This way you will be totally ready to rock and roll with a higher PSI turbo system (15-20 PSI) not to mention it will be bulletproof. I estimate (if you do all the work yourself) the pistons, rings and rods will run you a little more than a grand. Just my .02 though, if I wasn't so poor it's what I'd be doing!
