2BN_S13 wrote:OK tell me if im wrong, but displacement doesn't change at all and you are only decreasing the total (adjusted) cylinder volume. Since you have the same quantity of heat in a smaller area, are you not going to have higher pressure and thus more heat coming out of the exhaust as well as into all the surrounding metal? Heat doesn't push down only, you know.
heat is because of wasted excess energy, its like a seesaw, more energy spent pushing... less left for heat. can be the other way around too. It wont be dramatic like 300 degrees cooler, but there is a difference.
im behind you on this one C-Kwik!@!@!!!!!! *puts fists up*
