highbeam problem on S13
Team_Undisputed
Car: 90 240SX (Piggy)
hey guyson my s13 everytime i go to turn on my highbeams my regular lights shut off so basically i have no high beams any body know what can be wrong? can it be the switch itself?
madmeg323
stalk could be bad.. I had almost the same problem, but it was only the driver side, so I jumped the passenger to the driver side for high beams.
Hope this helps
ZOMG.SR20
Car: 1990 s13
follow the wiring and check for faults
Team_Undisputed
alright cool thanks for the replies guys does anyone have a layout of where the highbeam wires would be so i can follow them?
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
Team_Undisputed wrote:alright cool thanks for the replies guys does anyone have a layout of where the highbeam wires would be so i can follow them?
i had the same problem. Make sure that all of your lights are on. I looked around my car and almost nothing worked. I thought my headlight was just the problem but after spending hours of looking at wiring diagrams it was the stalk. If more than one of these lights are out then it might be the stalk because on the wiring diagram they are all in parallel with each other.
Front/Rear Side MarkersTail Lights (Not Including Stop Lights)License Plate Lamps (both left and right)Glovebox LampAsh Tray LampAll the lamps in the Console (behind Speedometer, Tacho, Brake, etc...)
Take a walk around your car because I ended spending more money changing the headlights, fuses, and bulbs in the car than checking the wiring diagrams.
http://www.nicoclub.com/FSM/240sx/ (All 240sx Manuals)http://www.nicoclub.com/FSM/24...t.pdf (HUGE DIAGRAM)
The diagram is from a 93 s13 but it should be the same seeing as the stalk that i have came from an 89. Happy Hunting
