Highbeam plug fell into headlamp
RyanHopp15211
Car: 2015 Nissan Rogue
I was recently changing my highbeam bulbs and the plug/cord for the highbeam fell into the headlamp assembly. Does anyone have a link to show how to remove 2015 Nissan Rogue headlamp assembly? I'm assuming that I will need to remove it so I can get the plug back out.
Pull up the FSM at nissanservicemanual.com
Welcome aboard!
RyanHopp15211
I looked and all I can find is refer to EXT-17 (remove front bumper fascia) Maybe I'm just a noob, but I can't find that diagram in any of the manuals.
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
Unfortunately, to remove the headlight assembly from the vehicle, you have to remove the front bumper completely off the vehicle. Sometimes, I really don't get these design decisions that Nissan makes half the time.
RyanHopp15211
Yes I am aware that I will need to remove the bumper to get the headlight out. Does anyone know how to do that or perhaps has any experience with that very short cord falling into the headlamp?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
RyanHopp15211 wrote:
Sun Jan 03, 2021 1:24 pm
Just for future reference, we have an incredible SEARCH feature on this forum.
The instructions for removing the front bumper is the same for ALL 2nd gen models.
2014 ROGUE SL HEADLIGHT PROBLEMS
See also: Nissan Rogue Service Manual: Front bumper (Exploded View)
Not to be rude, but it won't matter if someone else has had that issue - the headlight (and bumper) still have to come out. Once the bumper is off, the headlight removal should be pretty self-explanatory.
It's a poor design, but it also begs the question why a 4-year old car needs new bulbs already. I'd be frustrated as all hell - not just about the bulb, but the dropping of the wire and the need to disassemble the whole front end. YUCK. Good luck.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
AZhitman wrote:
Sun Jan 03, 2021 6:36 pm
I don't get how you drop a wire into a headlight that can't be fished out with a bent coathanger. It's a wire, isn't it?
I suspect he's doing HIDs and it's the little wire with bulb assembly that's gone walkabout. But agreed.
VStar650CL
Technical Expert
AZhitman wrote:
Sun Jan 03, 2021 6:56 pm
Even then the housings are usually plain steel. Magnet instead of a hook. ;)
VStar650CL
Technical Expert
VStar650CL wrote:
Sun Jan 03, 2021 7:02 pm
PS - Advice from a wise old klutz who drops s__t all the time. :)
datechboss101
Even doing HIDs or LED swaps, those wires aint that long to fall into the housing. Usually it can be taken out without removing the assembly. That's what I can remember from the Halogen conversion from my 16, unless Nissan changed that setup from the 17 to 20.
RyanHopp15211
I was attempting to install LED's. The cord is very short. I tried using a wire bent into the shape of a hook and the magnet trick, but neither worked. The problem is that I can't see anything in there and I don't know where the cord originates from on the driver side. I can feel there is a wire cluster in there, but it's quite attached and don't want to yank it too hard.
Return to “Rogue Forum”
