GTR PrYdE »
https://forums.nicoclub.com/gtr-pryde-u29428.html
Fri Dec 12, 2008 8:27 pm
low impedence is never going to be as good as stock high impedence injectors unless you're on aem ems...
deatschwerks sells sidefeed high z, and ams has top feed high z injectors too, if you really want to switch to top feed- they're alot easier to install/remove than sidefeed, and as long as they're high z, and you cut/splice correct injector connectors they'll work fine.
