aero1310 »
https://forums.nicoclub.com/aero1310-u134819.html
Mon Jun 06, 2011 11:21 am
You say to use 6-6.5 ohm resistors so the stock ecu could read the fuel maps correctly. Im using the AEM ecu, think that changes anything? Also Ive been reading on other writeups on how to make your own resistor pack and they say you want a current of around 1 amp, but (correct me if i did the math wrong) with the 6ohm it comes out to 1.5amps. That just seems a little much and Im not sure I wanna risk frying my 1800$ ecu lol..
btw I have denso 550cc injectors that run 2ohms on a RB26DETT w/ AEM. Unfortunatly the engine didnt come with the resistor pack :P
Yeah Im just a little unsure what route to take, 10ohm, 8ohm, or 6ohm lol You make a good point but not sure if that only applies to the stock ECU...10 ohm sounds like ppl have trouble tuning.. anything bad about 8 ohms?
