pgt892 wrote:When you said high speed, I assumed 100MPH+, but "high" is a relative term. For me a good alignment usually solves the 65MPH vibrations.
Alignment has no effect whatsoever on shake/shimmy/vibration, nor does it deal with spring rates. Alignment and vibration problems are two different worlds. Abnormal/accelerated tire wear, steering wander/pull to one side or the other are the demons of poor alignment. Re-alignment will not fix a vibration.
Improper balance is a speed-sensitive issue. Meaning, that only at certain speeds will the vibration arise. Other possibile culprits are improper mounting of aftermarket rims without using hub-centric rings, out of round tire/tread separation, bent wheel, low tire inflation, bad road, or any combination of these...
