Royale240 »
https://forums.nicoclub.com/royale240-u235947.html
Tue May 27, 2014 8:11 pm
Hey Nico, I request your help once again!
I've been doing some research on some possible explanations on what's causing my current issue, but I'm not sure what exactly needs to be replaced or adjusted....Here's what's going on.
-I'm cruising along at around 70 and I downshift into 4th to accelerate up to around 90-100.
-everything is fine, everything is stable until I hit 85 mph when things start shaking.
-I hit around 90 mph and there's a very loud audible vibration that begins shaking the entire car.
-whole car is vibrating like crazy
-Steering wheel and shifter are staying perfectly still.
-Slowing down to 65 mph, I can let go of the wheel and not change lanes. no wheel wobble.
-Doesn't follow the symptoms of 'death wobble' or 'death sway'
-Car doesn't want to kick out or change directions at speed on on throttle, just vibrates like crazy.
-I don't feel any sort of vibration in the shifter or the wheel at any speed, or even when I hit 85.
I'm Assuming this means I have some sort of bearings / mounts or bushings that have worn out or have been destroyed. Everything handles great, and suspension feels good (Stock struts and springs, don't know if they have been replaced, Coils may be in the future. ) But at this point, It drives nicely, but I'd like to nail down what's going on in that suspension territory. Let me know if you guys have any ideas of what's going on.
