Uhh yeah... that post makes very little sense.Two Fowty wrote:limiter? maybe fuel pump or filter failure?
just an idea, not too sure.. something similar happened to my old 240 with the fuel delivery system. so check ur filter.. replace it if its not too new.. its only like 10 bucks.. pump however is a more annoying fix, so if filter doesnt fix it, do that..
I'm running a nonturbo KA, and it does it as well?? I was thinking pcv.xX RB Xx wrote:too much boost...
or egrdriftneil wrote: I was thinking pcv.
Walbro pumps are hit and miss even when buying a new pump.Theve been known to go out when they are under full load.I mean i cant say much,ive got one in mine,but it is a known fact and it is very possible that its cutting off because its over heating or just dieing.LOVERboy wrote:the filter looks pretty new ... so i dont think that would be it ... and the pump are the walbro fuel pump and im sure its not that old .... wat else can it be?
wat sensor? and how did u fix it?bloodspread wrote:my 240 used to cut out at 5500 rpm, it was the fith gear sensor was stuck on the on position or something like that, I just unplugged it and it never gave me problems again.
