NineOneQ45 wrote:possibly, but i doubt it... and H and an X pipe effectively accomplish the same thing...
Following excerpt taken from the Vette-Magazine articleThe "X" Files.
An H section is inexpensive to mass produce. It's better than no crossover or balance tube whatsoever, but it is fairly inefficient. Exhaust gases want to follow the path of least resistance--that's why smooth mandrel bends produce better power than crimped and uneven (i.e. the corner muffler shop) bends on exhaust systems. Unless forced, exhaust gases are not going to make the hard 90-degree turns you see on an H pipe. An H pipe will offer some benefit, but not a lot.
An X section, with gentle beds and an open center chamber, offers substantially better balancing or equalizing of the exhaust gas pulses than are possible with an H crossover. Ergo, an X crossover should, with no other changes, offer enhanced power production. It should also eliminate the burbling and popping on deceleration that's not especially uncommon on aftermarket C5 cat-backs. We'll see.
Danisiti 1
