a good way to start would be with a butchered and balanced crank...
i told darren at fast forward that he should contact the niconauts. i haven't seen him on here, but these guys have been in the dsm world for a while and have a good reputation.
http://www.ffwdconnection.com/butchercrank.shtml
the key to high-revs is a balanced rotating assembly and a built valvetrain. removing rotating mass (butchering the crank, lightweight clutch/flywheel, lightweight crank pulley) and reducing drag (lightweight rods/pistons, lightweight pullies) is also a great way to add to your redline; however, it's not going to do much good if your rotating assembly is out of balance. as far as building the valvetrain goes, you need to build your valvetrain (springs, retainers, lifters) that can withstand the higher rpms and stresses.
something else to keep in mind, of course, is that with higher rpms you get higher temperatures. so you'll need to keep things cool. i'd suggest getting a bigger radiator with dual fans and running an external oil cooler setup.
just my $.02
