Jberger »
https://forums.nicoclub.com/jberger-u226.html
Wed Jul 02, 2003 4:27 pm
Sounds like a pulley, but it should be easy to identify with the hood up. You might wanna invest in a cheap mechanics acoustic scope (4-5 bucks at harbor frieght) to narrow it down between the belts and the pulleys.
If it's a pulley, make SURE you properly tourque the bolt when you replace it, or the new one will burn out in short order.
Either way, go ahead and replace all the belts as it's a quick change while you're under the car and cheap maintenance.
