i have the msd blaster 2 coil..nifares240 wrote:sounds like you need a tune. you should upgrade your ignition to msd. this will make your spark bigger.
the injectors are 440cc or 470, i forgot. the fuel pump is a 255 walbro...stock fpr...nifares240 wrote:did you upgrade injectors and fuel pump?
