high revs = brake light come on
originalsin
ok i am baffled. when ever i rev my car out (today at the track) like once i get the rpms up my brake light goes on (like the ebrake warning light) the ebrake switch thing is disconnected, and my brake fluid is right where it should be and as soon as i shift itll turn off. wtf is this. freaks the hell outta me cuz i think its my oil light
UMS_CA18DET
Out of curiousity is the brake light come on when you get close to your Rev limiter? Also is the ECU chipped?
Just curious cause I know some Honda peeps can program their ECU's to light up things like certain cluster lights for their Shift light.
Also check your center console their is a switch on the ebrake see if it needs attention, it could be during the higher revs the vibration may cause it to pop into position.
originalsin
yea i dont think the ecu is chipped, the light comes on at like 6700-7000, a little b4 redline. so yea idk, ill check that wire tho
