zippyslug31 »
https://forums.nicoclub.com/zippyslug31-u73542.html
Tue Mar 18, 2008 6:55 am
Well if it's your dipstick, then I'd assume you would have (see) an oily mess in your engine compartment.Might be using oil though.... I'm likely in line for an updated engine through the dealer since mine apparently has an oil consumption problem. Your's might be trying to tell you the same thing?
My clutch also is pretty easy to smoke. If I drag it a little bit too much when I'm racing around you definintely can smell it.
But, oil and clutch really smell a fair bit different, IMO. If you aren't familiar with what smell it is, you might have a more knowledgable buddy ride along and "make it smell" for him to diag the prob.
