High Pressure PS Line Crush Washer Size
SanCarlosQ45
Car: 1994 Q45 144,000
2013 Nissan Xterra Pro-4x
1967 MGB GT Special
If anyone who has changed the PS pump or the High Pressure line could tell me the size of the copper crush washer that the banjo fitting uses that would be great. I got the car running and driving now, I just have a small leak at the fitting since I used the original washers.
OwnerCS
I can't tell you the size but the last couple that I purchased came from the local Nissan dealer that had some in stock. It appears to be a common banjo bolt size -- most likely used on Z32 during the same year period. I think the Phase 2 (94-96) G50 shares a PS rack with the Z32.
SanCarlosQ45
1967 MGB GT Special
Thanks, normally I look to see if something is comparable or the same because usually they are.
The racks, both NA and TT are very similar, they have the same high pressure fittings, mounts, and angle of the input shaft but some of the hard lines on the outside of the rack are in completely different locations. When I had my engine out I checked to see if a 300zx TT rack would fit because it has a faster ratio, but I think some of the hard lines may hit the oil pan.
