high pressure power steering hose
scho1123
Car: 2011 Infiniti M56 base
Has anyone had success making your own power steering hose... the hose my m56 needs is like 420.00 with shipping, appears to be leaking at crimp point....49720-1MC1A that's the infiniti part number
Ilya
Been around here a while and can't say I've ever heard of it being done. You may have to be the pioneer and document the process.
DCHammer
Car: 2011 Infiniti M37x
If you have the equipment to make hydraulic hoses and the necessary fittings, you'll be fine.
That's really all it is. A high pressure hose with special fittings.
If you came make a hydraulic hose that handles 4500PSI, you can make a power steering hose.
The challenge MIGHT be the fittings.
If you can, remove the hose and go to a tractor shop. Like a New Holland or John Deere dealer. Or a specialized hydraulic shop. If they can get the right ends, they can make you a hose.
EdBwoy
Ditto ^^ . The only special parts to an OEM hose are the ends, but the hose itself can be sorted out with standard supplies.
With my M45, I took the high pressure PS hose to a Parker distributor, and they cut and reused the special fittings.
If you have some time, check out this video.
