High Pressure in Upper Rad hose?
danman04x
Car: 1992 240sx hatch/RB20 swap..05 Scion tc..01 CBR600 F4I
Hey everyone, I have an rb20 in my s13 and im wondering if any of you have really high pressure in the upper radiator hose. I feel like when my car is running the upper hose feels like its going to burst. I was told that it might be because of the short length of the hose but was just wondering. Im currently just using a regular hose, do you think upgrading to a silicone hose would be less prone to bursting?Thanks
Nissan2367
Mine is the same, so have all my other cars i have built. Its normal all antfreeze is under pressure. It even does it on my MDX
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
you can run the silicone pair of hoses, pressure should be 12 or 14.7 psi under the hose, of corse itll be hard (thats what she said)
danman04x
aight thanks. I kno this has probably been covered before but would a set of silicone hoses for a ka24de fit my rb20?
Nissan2367
You will have to cut it apart. I used some from a s13 and just cut them apart.
Joe
danman04x wrote:Hey everyone, I have an rb20 in my s13 and im wondering if any of you have really high pressure in the upper radiator hose. I feel like when my car is running the upper hose feels like its going to burst. I was told that it might be because of the short length of the hose but was just wondering. Im currently just using a regular hose, do you think upgrading to a silicone hose would be less prone to bursting?Thanks
its normal...
Bluefire
Some pressure is normal, but if its to the point where the hose feels like it could pop or you cant even squeeze it, there might be a problem. I've encountered a few cars that had tiny headgaskets leaks. It would leak compression into the water passage under boost. Also since it would only happen under boost, compression and leakdown showed no signs of leakage. I only figured out the problem by just going ahead and changing the headgasket.
-Bluefire
danman04x
Yea it feels like alot of pressure. It doesnt feel normal to me and I work on cars everyday. Only thing is I replaced the headgasket before I dropped the motor in. People at my work tell me that its because the hose is so short. Im usisng a cxracing radiator with a 1.1 bar cap which is more than the normal ka24de cap which I believe is .9 bar. Could that make a difference?
CDub7
Car: 89 240sx rb25det
i was also worried about my cooling system have to much pressure but i was running stock s13 rad and blew 2 of those and upgraded to 2 core aluminum nismo thermostat and 1.1 cap and still has pressure in top hose but was told its ok. . . . we will see when i club the piss out of it (:
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Length of hose has absolutely NOTHING to do with pressure. Your coworkers are probably just used to working on domestics with 2+ ft of hose length on both the upper and lower rad hoses.
If the pressure was getting higher than you thought was normal, look at the radiator cap first. If it is sticking closed and holding pressure higher than the spring is rated for (i.e. it isn't opening and bleeding off to the reservoir), replace it. If that doesn't work, do a leak down test to check the head gasket. If that's not it, you're paranoid LOL
gawdzilla
Car: none
are you talking about pressure when the coolant is hot, or pressure when the car is just running (cold start)? if it's the latter, you might have a head gasket problem. when it is hot, you will see about 10-14 psi of pressure before the radiator cap blows. higher if you have some aftermarket cap.
the purpose of the radiator cap is to raise the boiling point of your coolant, not to handle some pressurized coolant for no reason.
