http://autospeed.com/cms/A_110298/article.htmlThe straight intake ports were designed with what Nissan terms an ‘aerodynamic port shape’, that is, a port that decreases in cross-sectional area as the runner/intake port gets closer to the intake valve. The ports were also positioned high in the head, so reducing the angle which the air had to negotiate before entering the combustion chamber. In addition to improving flow, the greater length of the port served to improve torque through giving a longer tuned length to the intake port/intake runner combination. In fact, a combined intake port/runner length of 450mm was used in the SR20DE engine. Compared with a low port design, the high port design improved measured torque by 4 – 7 ft-lb at engine speeds of over 4400 rpm.
Sorry for the old thread post!
