ok, now i have a new problem and will do my best to describe it. engine is an r32 rb20. under load, usually around 3-4000 rpm I get this high pitched whistle/noise. it starts off low pitched but rev it abit higher and it gets..higher pitched..yeah. cant seem to figure out what it is. fresh oil change, checked all the couplers for the front mount intercooler piping. checked as many places i could for some sort of leak that would give me an indication of why its doing this. also the exhaust sounds abit different like there is a leak somewhere, sounds more like an old truck now and every now and then when shifting or rpm drops i get a pop out of the exhaust, usually abit of fire. it tends to want to just die on me as well. starts fine but from time to time if i dont hit the accelerator pedal, the rpms will just drop until it dies. any ideas? here are a list of my mods incase something might be related. here are a couple videos of the sounds if that will help more.
http://s25.photobucket.com/alb...3.flv
http://s25.photobucket.com/alb...2.flv
ARP Head Studs,GReddy 1.2mm Head Gasket,GReddy Timing belt,Fidanza adjustable cam gears,Hybrid FMIC and piping,Turbo XS BOV,HKS pod filter,3" exhaust with Fujitsubo NGK axle backGTR fuel pumpKoyo radiator w/ dual 12" fans,GReddy EManage,GReddy Profec E-01,GReddy Auto Timer,HKS Hypermax D coilovers,front camber plates,Cusco front strut bar,Cusco front tension rods,
