gowhoosh »
https://forums.nicoclub.com/gowhoosh-u169607.html
Fri Feb 25, 2011 10:35 pm
I can't watch the video right now because I'm on a government computer, but it sounds to me like you are having the same problem as me. The squeal is annoying as hell, very loud, and only noticeable under load. If I'm cruising and it's screaming at me, as soon as I push in the clutch or let off the gas it goes away. I replaced my Goodyear Eagle F1's which were balding with Falken RT-615K's, and the noise didn't change. I replaced the Center Support Bearing/Carrier Bearing/Midshaft Bearing with an OEM replacement, as the old one was shot, and no change. I replaced the right (passenger side) rear wheel bearing (what the previous owner's mechanic had declared the problem as) with a new OEM one, but it didn't help in the slightest. I attempted to change the diff oil but stripped the drain plug, but I believe that's the next logical step before tearing apart the diff and breaking out gear marker. As I assume it is with yours, the sound in mine is VERY hard to locate. I have a 2 seater, and have had multiple passengers try to move around and narrow down the source of the squeal, to no avail. I have had a friend drive it on a 4 point lift, alternating from 60 to 80 mph every few seconds, as I was underneath hunting, but it didn't make a sound at all; it only is noisy under load, which leads me to the differential. Although it does sound like the rear of the car, I'm not eliminating the transmission as I think my synchros are bad, on top of [most likely] 120k miles on it. If I figure it out before you, I'll make sure to post on here with the solution. Good luck man.
