High-pitched Gear Whine
Katapl
Car: 91' R32 Sedan
I bought an S13 with a CA swap and as I drove it 20 miles home, I noticed it had a really high-pitched whine when I went through gears. Just getting it to 3k rpms in 1st was like driving it at 5k rpms in reverse. It was a damn loud whine noise. I figured it was low on transmission fluid, and it was. I filled it full, but it still makes a high-pitched gear whine in all gears. I'm not sure why. Any help?
It also makes a vibration noise with the car in neutral, but when I push the clutch in, it stops. I'm guessing that's a bad throw-out bearing.
90nissan240sx
Car: 90 Nissan 240sx
r u shure its coming from transmission and not the rear end? it might be diff. or a bearing...
Katapl
Car: 91' R32 Sedan
My father and I had both agreed the noise meant it was low on transmission oil. As we drained it, less than a quart came out! I filled it with 2 1/2 quarts (which is basically what the CA FSM said was pretty close to). The noise still persisted. It comes in at as low as 2k rpms, and gets louder as I bring the RPM's up higher.
I'm quite sure it's coming from the transmission, but I could always be wrong.
Katapl
Car: 91' R32 Sedan
MomentumGT
Car: 89, 91, 95 240sx
Had the same problem a few years ago when my sr transmission went out. I swapped the bell housing to the used ka transmission which had the high whining noise. 2 months later with infrequent driving the ka swapped transmission went out also. Drained the oil and there was nasty metal shavings with the oil. From your description your transmission might be on its way out.
-Jon
Katapl
Car: 91' R32 Sedan
That makes sense. Being that it was driven 20 miles and who knows who long before that on about 1 quart of gear oil. Rather than the recommended 2.4
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Anyone consider that the turbo may be going out?
Katapl
Car: 91' R32 Sedan
98s14inaz wrote:Anyone consider that the turbo may be going out?
I doubt it. It just doesn't seem like something that comes from the turbo. I can keep it in neutral and give it a bit of gas, and there will be no whine at all. It's definitely gear-related.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Katapl wrote:I bought an S13 with a CA swap and as I drove it 20 miles home, I noticed it had a really high-pitched whine when I went through gears. Just getting it to 3k rpms in 1st was like driving it at 5k rpms in reverse. It was a damn loud whine noise. I figured it was low on transmission fluid, and it was. I filled it full, but it still makes a high-pitched gear whine in all gears. I'm not sure why. Any help?
The transmission input shaft bearing is shot; pushing in the clutch pedal disengages the transmission from the flywheel, so the transmission input shaft stop turning.
pr240sx
Well, basically ANY bearing inside the transmission could be shot.Could be any. Open,check and replace.
When my first transmission blew, I ran and ordered the front input mainshaft bearing from Courtesy. 2 days later and 90 bucks less and the faulty bearing was the main COUNTERshaft bearing in the center carrier.
I scrapped the transmission and bought a used one instead.
98s14inaz
There is no load on the turbo while you are in neutral, not building boost, so there will be no whine. It is worth a check before you start ripping your transmission apart.
