SmithSR wrote:Where precisely did you spray WD-40?
During the work, did you accidentally bend the backing plate to where it touches the rotor?(silly, but it does happen)
Did you replace with an aftermarket rotor? OEM?
What is your experience with braking systems? The WD-40 bit scares me... maybe the wording used is confusing me, but it sounds like you sprayed the WD-40 directly onto your rotor/friction material.. very bad idea.
Perhaps the reinstall of the caliper on that side is not exact...?
I'd take 'er apart again, and look for signs of scraping on all surfaces.
_______________________________________________On the wheel bearing (the very middle of the wheel)
I did bend it back a little, but I will double check again
Aftermarket rotors
First time doing it, no I didn’t spray the rotors
Hmm…might be will check again
Scrapping surfaces, got it___________________________________
Also the squealing only happens after 15 min of driving when the wheels/brakes get warm
