They work!mbmbmb23 wrote:Didnt we find out before that VG springs will work???....because there will be more aftermarket options in the States for those engines. Can anyone confirm this?
thanks,
-M
So which ones do I get, or can I get any valves, springs, and retainers from a VG30DETT. Let me know I need to order these things ASAP. I want to be able to rev to 9krpm. I will be installing cams at a later date so i know stock cams wont make power that high but since I am getting head rebuilt might as well get these things installed now than later, cams I can just pop off valve covers and do it myself, springs retainers valves are more complicated.boost_boy wrote:They work!
Dee
Contact Jim Wolf Technology and they'll sell you set for around $240ish U.S. That model would be VG30 with DOHC engines (preferrably DET).OmarM wrote:
Now do I ask for CA parts or do I ask for VG30 parts? Also 240ish what does that include? Is it just springs and retainers, or are valves included? Also when I order, do I just buy a kit for the VG and have spares or can I buy individually? Sorry for the many questions but you seem to know the most about this topic.boost_boy wrote:Contact Jim Wolf Technology and they'll sell you set for around $240ish U.S. That model would be VG30 with DOHC engines (preferrably DET).
Dee
As for springs and retainers, you don't really need those unless yours are damaged, so save your dollars. And as for the springs, ask for Ben and tell him you want valve springs for the CA18DET. They will send you 16 of them and they are Heavy Duty springs for the VG30 dual overhead cam series. Remember, do not ask for VG30 springs or you'll make things confusing. And the price is around $240 for just the springs (they aren't cheap).OmarM wrote:
I just want a head that will be able to rev to 9krpm no problems? Will stock valves handle 9krpm or should I upgrade those as well?
Thanks for any information you may provide me with.
Omar M
Those are high performance springs that will fit our cars. Like I stated in my previous post, why fix something that isn't broken. These items on these engines were designed for extreme duty. If you have concerns, when your machinist or you tear down the engine, have them inspected very well for wear, cracks, and fatigue. I doubt they'll need changing. I've never changed mine and none have never failed.Nowhere wrote:Are thoes OEM springs??Are new retainers sugguested?What about the lifters?
