High output alternator for G50
Trumpkin
Car: 1995 G50
I have a electric fan installed on my G50. It pulls quite a few amps. Has anyone upgraded the alternator for this reason or other reasons? Also who could do something like this? Can I buy one somewhere? I know some do not feel this mod is worth it, but non the less, Any input would be welcomed.Thanks
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
How did you install the fan?
When does it turn on?
Give us as much info as possible.
And there are aftermaret souluions, I remmber I saw an old thread some where around here so look around.
Trumpkin
Car: 1995 G50
It's a universal fan mount. It uses a thermostatic switch to turn on and off. It makes a difference with no fan clutch.
Infinitiguy19
But where did you find the room to mount it do you have pics?
Is there any way to have the fan stay on after turning off the car?
Trumpkin
Car: 1995 G50
Once you take out the stock fan/clutch and schroud there is plenty of room.It depends on how you wire it. It is a thermostatic switch.
Thread is way off topic!
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
any local starter electrical motor rebuilder should be able to upgrade your stocker. I have done this before with good results. They take your alternator and add custom windings
Example
http://www.highoutputalternator.com/customshop.htm
Trumpkin
Car: 1995 G50
Thanks. I am running a reman now. Already went bad once. But the car sits. Maybe I'll get a quote on a oe and upgrade that.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Don't see any benefit as the viscous clutch will only engage when there is not enough air moving, usually at idle in hot weather and never on the highway or at WOT.
However, the horsepower drag from turning the higher capacity alternator required to power it will always be present.
Infinitiguy19
Trumpkin wrote:Once you take out the stock fan/clutch and schroud there is plenty of room.It depends on how you wire it. It is a thermostatic switch.
So you have completely removed the OEM mechanical fan and added a electric fan right?
There is no gain beyond not having to replace the fan clutch which is a rare failure.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Paul Wall wrote: There is no gain beyond not having to replace the fan clutch which is a rare failure.
Actually, I think there is a net power loss as now the engine is powering a larger alternator continuously.
Q45tech has an interesting post that mentions the same thing.
Skibane
Car: 2000 Q45 AE 110K
maxnix wrote:Actually, I think there is a net power loss as now the engine is powering a larger alternator continuously.
"Continuously" is probably an overstatement. The alternator only produces drag when it is actually generating current...and the fan only draws current when it is actually running. Typically, the thermostat is set to turn on the fan only when supplemental cooling is needed. The rest of time, the fan's contribution to alternator drag is nil.
Meanwhile, a belt-driven fan is always producing some drag, because the viscous clutch never completely disconnects the fan from the pulley - The fan "freewheels" at some speed that is lower than engine speed, drawing some engine power in the process.
My biggest problem with electric fans is that they rarely are capable of moving as much air as a properly-functioning belt-driven fan. There are times when you actually need 5 horsepower worth of air movement - and the laws of physics say that a half-horsepower electric fan motor just isn't capable of accomplishing the same thing.
Q45tech
Be careful about so called high output alternators. Important to understand and create a graph of amperes per alternator rpm and divide by pulley ratio............to equate to engine rpm.
Having higher current at 2000 engine rpm doesn't do much good with idling in summer traffic.
Rex
Car: None
From my days in "excessive car audio" a couple decades ago, I'm aware of some of the options for higher output alternators. My biggest concern if I were looking at one for a Q45, would be the RPM's it would see. Since so many were on non-daily drivers, I can't say what the real world life span is, but would think they wouldn't like seeing ~6500 RPM's very much.
Denver90Q
Car: 1990 Q45 145K miles beige, 1995 Q45t green 80K miles , 1998 Frontier 140K miles black
Trumpkin wrote:Thanks. I am running a reman now. Already went bad once. But the car sits. Maybe I'll get a quote on a oe and upgrade that.
How many amps are you drawing and how old is your battery?
Trumpkin
Car: 1995 G50
Rush hour traffic is not a concern.
Trumpkin
Car: 1995 G50
Brand new optima, from what I remember it's 17amps with fan on.Do I even need to worry about it? Or should I let it ride?
Denver90Q
17 amps is only about 200 watts (like two light bulbs or highbeams on headlights). I wouldn't worry about it. Those alternators are a pain to take off.
Q45tech
Interesting that most alternators are only 50-55% efficient so that 746 watts needs 2 horsepower to turn so 110 amperes out needs 4.36 HP of input.
"Efficiency of automotive alternators is limited by fan cooling loss, bearing loss, iron loss, copper loss, and the voltage drop in the diode bridges; at part load, efficiency is between 50-62% depending on the size of alternator, and varies with alternator speed"
http://www.windstuffnow.com/ma...s.htm
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
So you drive only at night? Headlights then are an extra load.
