high or low impend.
hek1620
Car: '89 240sx
i have the denso(rx-7) 550's which model number ends in 2010. i now there's a chart around some where that shows them all but i can't find it. i need to know if these are low or high imp.. thanks.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Use a muti-meter...if they are ~11ohms, they are high impedence.
Just hook up the 2 tester leads to the 2 pins on the injector, easy stuff.
- Brian
hek1620
Car: '89 240sx
if they're low imp. can i make them work somehow?
teddy
Car: Saab Turbo and MR2
Those injectors should be low impedance, but in the case that they are high, you just wire in some resistors to drop the impedance.
hek1620
Car: '89 240sx
the guy at the shop put it on and it hit 24 ohm. i don't know whats that means.
