BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Thu Sep 30, 2004 1:50 pm
I seem to be getting pretty high oil pressure numbers compared to other people and I'm curious to see if anyone might know whats going on.
THis is my 2nd SR, and both seem to have shown similar numbers.
I am using an Autometer electonic gauge, and it shows aroudn 75psi at idle when cold, when it warms up, it shows around 70psi at crusing RPMS (2000-3000) and at idle warm it shows around 25 psi.
Well I recently fixed an oil leak, and switched to 15w50 oil, and my pressure sending unit died the next day. I figured that maybe the sender was bad from the start since its not that old, so I got a new sender and now its showing even higher pressure. Its showing 75psi at cruising speed and 35ish at warm idle. I have the sender attached to my greddy oil relocation block, where the filter screws on.
Are these numbers high, if so, why would they be so high, and would just fixing an oil leak and going to a thicker oil cause an increase in pressure?
