High Octane Tune for SOHC + Cam
Edub1
Car: 89 240sx KA-T
I'm considering a cam, exhaust & emanage setup & I'm wondering...
What is the best way to tune for this setup? Timing, A/F ratio or both?
I've searched quite a bit and it seems that there are a number of opinions regarding timing and piggie backs.
One opinion is that cutting back air/fuel ratios will cause the ECU to advance timing. Is this true for a very modest, say -5% cutback durring open loop operation? I wouldn't think the ECU would react too much to -5% A/F ratio under wide open throttle. Also, I don't have to monkey with A/F if going all timing is better. Or visa, versa.
I guess my question is, what combination of timing vs A/F ratio is going to give me the best power gain on a N/A setup with cam, exhaust & 94 octane?
Also, my SOHC distributor doesn't rotate.
tonynalli
why doesnt it rotate??
Edub1
Car: 89 240sx KA-T
My understanding is that this is all done with the ECU.
tonynalli
done with the ecu/???huh.. there is a little screw on the end of the dist. that spins off of i belive somethign around the timing chain area....but can you not remove it..there are two bolts that hold it in..one on the top and one on the bottom.
Edub1
Car: 89 240sx KA-T
Dude, WTF?
