mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Thu Jan 31, 2008 7:35 am
Boost? I say go turbo. Here's my opinion on supercharging and turbocharging. Had a recent discussion about this so am doing a bit of copying and pasting of what I said.
Quote »As far as superchargers go, as an alternative to a turbo setup... I would only go with a screws supercharger if at all possible. If you only have the options for a centrifugal or roots s/c and a turbo setup... the turbo setup will be the most efficient and will offer the most potential. The centrifugal is too peaky (peak boost at redline), roots isn't efficient enough but will offer a lot of low end, whereas the screws is the best of both worlds... very efficient while offering incredible low end boost/power. Still doesn't hold ground to a turbo setup when it comes to peak performance/efficiency from what I've seen, though in most cases the screws will have better low end power (variable turbochargers will completely change this though and have already, though they are still quite expensive and somewhat difficult to get).
There are some benefits to the centrifugal and roots superchargers... though not enough of a benefit to use them when other options are available in my opinion.
The centrifugal superchargers are very efficient, under hood temps are generally lower, they are easier to run an aftercooler, but the biggest benefit is they are pretty compact and are generally the easiest to setup. Generally you'll see these setups producing the most peak power but low and mid range power is minimal compared to the other options since they don't produce peak boost till the engine's redline (boost is linear).
The roots supercharger's benefits are very high reliability, inexpensive, readily available, and produce boost very fast for incredible low end power... they are awesome choices for a good performance street car since the majority of a street car's life will be in the low to mid rev range. The downside to them is they are very inefficient as they are not air compressors. They are simply blowers that move more air than the engine can take it causing the air to compress in the intake manifold itself. Eaton's new TVS rotor designs have improved efficiencies to a peak of 76% adiabatic (heat) efficiency on some models, which is quite impressive but the screws is still superior (not to mention the TVS's are new enough that they will be quite expensive and probably hard to get). The original designs will have less than 70% adiabatic efficiencies, larger blowers being closer to 60% (based off of the Eaton models).
Downsides to both the roots and screws superchargers is they are generally mounted directly to the manifold, which means a manifold must be made for your engine to mount it. Mounting them to the manifold causes the other potential issues being that they generally are pretty tall having a supercharger on top of the manifold meaning some setups may require a different hood. The other issue is that they are more difficult to aftercool. Screws superchargers are efficient enough that you can run a bit more boost non-aftercooled compared to the roots which simply means more power. For high boost setups they really need to be aftercooled. This can be done but requires a water aftercooler to be mounted between the manifold and supercharger. Some manifold setups actually allow the aftercooler to be mounted inside the manifold itself, from what I've seen, which will take away from the space issue but are expensive.
Other routes I've seen for mounting the roots and screws superchargers is a "remote mount" setup, where the unit is mounted to the side of the engine with piping going to the intake (just like a turbo or centrifugal supercharger). Now... I'm not positive on this... but I believe in this instance a screws supercharger would work much, much better since it compresses the air. I've seen these setups done with roots superchargers with good results but I would think efficiency would be extremely poor since it has a lot more volume to pump then compress... but like I said I could be wrong.
The roots and screws superchargers are internally lubricated (have their own oil supply, as do most centrifugals) and can be mounted in just about any angle from what I've seen and still lubricate properly (standard horizontal, vertical, 30°, 45°, etc.) which makes it a very possible setup. Doing this would also make it much easier to use an aftercooler, you could use a standard air/air unit. The only downside to this is the units are pretty big and in most setups you would have a hard time mounting one this way as the accessories will likely be in the way. If you don't have a power steering pump or a/c compressor it would be easier to mount most likely.
One last thing to consider is most roots and screws superchargers use at least an 8 rib pulley/belt. I think some might use a 6, but if so it probably is a smaller unit. The more ribs there are the less slip will occur. I would try to run an 8 or better if possible but this does mean custom pulleys if none are made for your vehicle.
One thing to note that turbo charger setups are a lot easier to do when it comes to custom applications than the supercharger routes since most of those require pulley setups which usually means custom machining of various mounting parts. Custom machining for turbo setups generally stays at flanges which are cheap and easy for machinists to do most of the time. Just more to consider.
All of this info is stuff that I've seen over the years of studying different setups so my info may not be absolute 100% but I'm pretty confident on the info.[/quote]
