Check to see if there are any puddles or dampness around any of the injectors. If you see any, you have an excellent opportunity to replace the injector gaskets. They're pretty cheap and not horribly difficult to replace, so maybe do it regardless?
Replacing the PCV and crossover hoses is probably a good idea too. Both of them were pretty rotted on mine. The crossover is a hose that runs between the valve covers so that a PCV valve isn't needed on either side. The crossover is molded, so your best bet is to buy an exact replacement, but I used bulk hose without too much trouble. Sorry, no idea what size the hoses are.
I also replaced all of the hoses on the vacuum gallery the same day I pulled the intake runners off, though you can really do that anytime.
You know to replace the intake gaskets when you pull the runners, right? Fel-Pro makes a great gasket kit if you don't have one already. Also, immediately plug the intake manifold with rags or paper towels or something so you don't accidentally drop a nut or bolt down the intake manifold. One of the other members here did that not too long ago and is still posting updates on his adventure getting the metal bit out.
Another note while I'm thinking of it: on my 2001 I needed a slightly longer 10mm wrench to access one of the bolts on the backside of the intake. The one I had was just slightly not long enough.
What year is your QX4? I had an 01+ in mind when I responded, but the ideas are probably applicable to previous years.
Good luck! That's a fun weekend project
