Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Feb 06, 2003 6:19 pm
The problem is that most CAS are actually cam angle sensors driven thus they read the exhaust cam after the drive chain [which runs at half the rpm of the crank] and any chain stretch makes them read late. So a 3 degree stretch means that while you can adjust the CAS to read right with the crank [that's where the timing marks are [as the trigger is off of #1 plug] the whole intake AIR system gets progressively retarded [valves open later and close later] [which on Nissan designs tends to raise the point [rpm] of HP peak at the expense of low end torque.............the fuel is injected within the broad intake window [248 degrees] and has adequate margins on each side......valve opens then, wait, then injector starts, injection stops, wait, then valve closes [17% margin on each side of curve].
The optimum ignition is not affected though the optimum mixture may not be present [at low rpms] after you readjust the CAS for chain stretch!Genenerally the chains don't stretch 3 degrees even after 250,000 miles of use as the forces transmitted through chains are small [smaller than US V8 which use twice/thrice as stiff valve springs and high friction pusrods and lifters, heavy valves, etc].
THE VVT covers up much as the idle position [20 degrees retard on intake] is designed for very very very smooth idle.
