High impedance injectors on CA18det?
Audiofan
Car: 200sx
Can I use High Impedance injectors on my CA18det (originally uses low impedance with resistor box) by eliminating the resistor box???
works? or I could damage the ECU?
Has anybody done it?
PapaSmurf2k3
Site Admin
I don't see why not. Are you going for stock sized injectors, or something bigger (with something to control them)?
Audiofan
Car: 200sx
Bigger! with something to control, probably aem fic
PapaSmurf2k3
Site Admin
Yeah, you should be fine.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Anytime you look at high Z versus low Z injectors, just be sure you have a resistor setup for the low Z, or remove it for the high Z. No harm comes from by passing the resistor pack for swapping your CA to high Z injectors.
