coldblooded »
https://forums.nicoclub.com/coldblooded-u7403.html
Sat Sep 06, 2003 8:18 pm
So I recently swapped in a fresh KA24DE (~40k miles, spotless motor) and swapped from auto->5spd in my 93 SE. From the first time I started it up, it's been idling in the ballpark of 2k RPM. Sometimes it sits at 2-2.5k, other times it bounces up & down (varying rates) from 1.5k-2k. When it's really warmed up & sits at a light for a minute sometimes it will settle into a 1.5k fast idle.
1. ****ed w/ TPS...looks like auto vs manual is different. Yanked throttle body, made sure butterfly was closing good, and put auto TPS on there (it has an extra plug for closed/open throttle). This, of course, made no difference. Adjusting it up or down changes characteristics of bobbling and increases RPM, but never drops below 2k.2. Visually inspected for vacuum leaks. Noticed a solenoid on the back of the drivers side was broken, hose bib broke off probably when dropping engine in. Replaced solenoid (from old engine), replaced hose. No difference, of course.3. Tried adjusting IAC valve. Upon disconnecting TPS, idle shoots to 3.5-4k, IAC adjustment makes no difference whatsoever (screwed all the way in or about to fall out). Removed IAC adjuster screw, sprayed screw & hole w/ carb cleaner. 4. Tried checking air regulator (put channel loks between intake runners & pinched hose that goes into it). No difference, to my surprise.
Any ideas? Seems to me like either the air regulator is fuct, or the butterfly is somehow not sealing well enough to actuate the idle air control. I can't find many more ideas from the FSM.I have an AIV/PAIR removed (vacuum lines capped at throttle body), Injen intake (AIV extras & everything capped/sealed appropriately). ECU is still from the Auto, clutch circuit is shorted for ignition. All else is stock besides the lower heat shield being removed. No CELs or other problems. All electrical connections were checked relatively well when swapping. Engine pulls like crazy & runs amazingly in all other situations.
