lylasohc »
https://forums.nicoclub.com/lylasohc-u173471.html
Tue Nov 30, 2010 12:37 am
hey.
i have a 1990 ka24e and every since i have had it it has always idled at 1k but recently it has been high like up to1300 and when i give it gas it sounds like it wants to die but goes back up. ive tried adjusting the idle, change the timing from advanced to retard and in between, messed with the bolt to adjust the throttle. ive cleaned out the iacv-aac and seafoamed the engine. i have also change the spark plugs, spark plug wires, distributer cap and rotor(seems the cap and rotor are wearing out fast). still no changes.
here are a few things wrong with it. theres a leak from the power steering and it leaks a little from the valve cover. there also seems to be a vacuum leak but i cant find it and my headers that connect to the downpipe is missing a bolt so there could be an exhaust leak that i cant hear cuz of my cat back. it also seams that my alternator could be going bad too. i hear a clicking noise like if a lobe is messed up and sounds like the injectors are making a loud squiting noise
so if anyone out there can help me i would be a happy camper.
thanks
