Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Jun 14, 2003 10:03 am
The problem is [if someone ever misadjusted the IAC bypass screw to raise the idle to compensate for a dirty throttle body].
The REAL idle speed is critical and the interior tach is not accurate enough to tell the difference between 650 and 675 rpm....or even 700 rpm.
The TPS must be adjusted hot so that the ecu sees 0.40-0.45 volts after the the engine has been at 176F or hotter......but not above 194.9F for at least 10 minutes [to make sure the hot wax fast idle cam is totally disconnected].
Then you set, reset, or leave alone the IAC bypass screw [usually 2.5-3.0 turns out after you have bottomed it............what you want is the IAC percentage [pulse duty cycle] to be no less than 10% and no more than 15% [idle in park, AC OFF]........then test to see that the IAC % goes up when in drive and up even more when AC is turned on [30-35%].
The ecu depends on having full and precise control of IAC, if IAC is not set right the ecu has to change the base timing [you don't want this to happen especially in summer as retarding ignition increases the heat load which may get you above 194.9F which decrease the advance more ........a cycle that just get worse as the coolant temp rises hotter and hotter the timing get lower and lower.............and eventually you can get in thermal overload and runaway.........where the cooling system can't control the temperature rise. [primarily due to rad not being 100% brand new].
All this from a mis adjusted TPS and improperly set IAC.
AS you all know in drive, AC on, stalled traffic eventually the system will overheat..........some cars take 5 minutes in 100F some 15 minutes, some 20 minutes of not moving.
Mu definition of overheating is for the coolant to get above 212F.
