BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Fri Oct 15, 2004 3:24 pm
My car has recently begun idling too high, its sitting at around 1000rpm when warmed up. I have tried disconnecting the battery, the Accelerator cable isn't too tight, the car runs fine, although my gas milage is down and I think it running richer than normal.
This all seemed to start after I removed my ECU and put it back in. I changed nothing on the ECU however. It could be coincidence that this all happened at once.
The car idles at 1500 or more when its cold, then drops down when its warm.
Where is the idle adjustment screw at? I tried the screw that I found in the middle of the intake mani on the AICV but it didn't seem to do anything, however it seems to be plastic, and not metal, and my screwdriver was starting to mess it up. It this the screw, or is there something else I should also try?
