Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Fri Jan 04, 2008 11:50 am
If you pinch the Aux Air Valve hose shut, it's pretty much proof the valve isn't working. It takes a minute or more to completely close when it does work which allows the engine to warm up a bit by adding extra air as if the throttle was open a bit.Take the valve off, and look through it. You should see a crescent shaped bit of light showing which indicates it's open. Now connect 12 volts to the 2 terminals and wait a couple minutes. You should now not see any light. If this is the case, then you have a connector or wiring harness issue.
To adjust your base idle, make sure the engine is up to operating temperature, unplug the AAC valve, then turn the screw on the side until it settles at about 625. Plug it back in and it should go to about 650 to 700, then you know the AAC is functioning. That solenoid sometimes quits working, or the assembly becomes gummed up with oil over the years. Take it off and give it a thorough cleaning as well as test the solenoid. !2 volts touched to the terminals should make it click. It's a vital part of the system so it's worth ensuring it's operational. PS - you will likely need a new gasket if you remove it.
