dhkemp91 »
https://forums.nicoclub.com/dhkemp91-u195240.html
Thu Jan 05, 2012 12:14 pm
Ever since i got the Z it has idled high. Its a '94 NA Manual transmission. Im beginning to slowly replace all the corroded connector harness all throught the engine. I just removed and cleaned the IACV. I removed the Air regulater and it looked good. I scraped all the connectors clean and I also bought and put on new harnesses for the 2 IACV connectors and the harness for the air regulator. I reinstalled everything and started with the adjustment screw all the way out. started the car and it was around 1500 after warming up. i started to screw in the adjustment screw and i got it down to about 900-1000 with the screw fully in. then, today i unplugged the negative battery for 30 minutes to let it reset the ecu. Hooked the battery back up and then I checked and adjusted the tps. It was around .425V fully closed and with throttle fully open it was like .37V which is low i think. The connector coming out of the bottom has all clean pins and clean connector, but the connector on the front of the tps has all corroded pins and the conecctor is even missing one of the metal inserts. (im wondering if this is my problem). I unscrewed the adjsuter screw again. I started the car and it went up to just under 2500 rpms at idle. So i unplugged the AAC connector on the AICV and it dropped to about 1500. i Screwed the adjuster screw in all the way and that got it down to about 700-750. but the second i plugged the AAC connector back in it shot up to around 1900. Before i started messing with anything it was around 1000-1100. Any ideas on what the problem is? Bad tps? Bad tps connector?? please Help!
This morning the idle is now at or Above 2000. When I turned the air on it went up to about 2250 which means the iacv solenoids are working right I think. Any suggestions would be very helpful! I'm running out of things to try. Thanks!
