Davo1111 »
https://forums.nicoclub.com/davo1111-u277766.html
Sun Oct 15, 2017 2:39 pm
Thanks for your response. I also suspected a vacuum leak, even though having a high idle in neutral and not in park didn't make sense to me. I checked twice, once with propane and once with brake cleaner. I also check the lines for any cracks or looseness, and found nothing. I still might try pressurizing the engine somehow and see if i can hear a leak that way. I hooked a vacuum gauge to the line going to the EVAP purge control valve and got 19.6-19.8 inHg at idle and 20.5 inHg at 2500 RPM. My OBDII scanner said 21.1. I installed the new MAF and let it warm up, unplugged TPS, restarted and checked the rpm in neutral and it was normal. All looked good. As I was playing with the OBDII scanner, graphing the O2 sensors, the truck had been idling maybe 20 or 25 minutes and it suddenly just died. I plugged TPS back in and tried to restart. Finally i got it to take. It sounded horrible, defiantly running rich. Black smoke from exhaust, shuddering, barely running. I put old MAF back in and it ran good, I put in nuetral and rpms went 1600. I knew I shouldn't have bought that cheap china MAF off Ebay!(I know,I know... multiple people on this forum said not to) My OBDII scanner shows that the EGR test is always incomplete. I may check into this, but I didn't know if that test took multiple starts and stops to complete. The OBDII also shows that the Bank 1 #1 O2 sensor is constantly fluctuating from .1 to .7 after warming up at idle. The Bank 2 #1 is mainly a flat line between .2 to .6 fluctuating only so often and then steady? I am not sure how a normal O2 sensor should look on a graph after the truck warms up or if there is even "normal". Thanks again for your input.
