Here is my problem, please help... I am idleing between 1300- 2000 rpm's...even when its warm. The idle adjusting screw only adjusts the idle around 100 rpms...its closed all the way ( I disconnected the aac, the adjusted the idle screw, then hooked it up again) I just installed the ka24de throttle body, and using my s-afc, adjusted the TPS so that it would read 0% at idle and 100% at full throttle... I am not sure what is going on. Do I need to disconnect my battery and let everything reset? If anybody has an idea of what this could be...I am open to suggestions and comments... and if you want to IM me i am Tweaktac on AIM... or email me at
[email protected] , anyway...please help!thanx,Troy
