Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Wed Jun 30, 2004 5:45 am
That's exactly what mine did, Neejay -
On really hot days, or when the engine was really working in traffic, the idle would adjust back down to 750. Which indicated to me that the fault was not with the IACC system, but with the ECU not getting the mixture or idle correct. And I had just replaced my O2 sensor also.
All the other times, it would stay at 1000 - 1100 and run rich, misfire, bog under acceleration, etc.
Try replacing the coolant temp sensor, it's $28 from Nissan (for DOHC) and takes all of about 5 minutes to swap out.
